HAL.PBB.AllocMemFail
Description
Memory for the displayed object could not be allocated. This may be due to the system running low on memory. This will result in incorrect programming of hardware tables and will impact forwarding of PBB conformant traffic.
Remedy
Check the scalability limit and compare this with the current configurations. Reducing the system configuration may help reclaim memory.
Severity
Critical
Message Text
Memory allocation failed when trying to allocate a %obj% structure.
Message Parameters
Name Type
obj String
Applicable Platforms
